I have extruded a hole in a part that doesn’t go all of the way through the part itself. I noticed after completing the part that the extruded depth of the hole isn’t correct. When I try to change the extruded depth of the hole, I don’t get the value that I originally chose for the hole depth, I get a Zero - please see the picture. Is there any way that I can change the extruded hole’s depth while seeing the original value that I chose for the depth? Any suggestions would be helpful. Thank you.
