Cant use sweep to subtract material
Using the sweep command to subtract a shape along a path from an existing body will allow more complex shapes to be formed and make the sweep tool more diverse. This is a feature I have used with many other CAD software.
This feature will allow users to create models of boats, cars etc instead of basic forms.
To allow the sweep command to be used in a subtracting format as well as an adding format.
I am unable to create complex forms without this feature. Currently modelling a boat and this feature would help a lot, along with curved fillets (only chamfer available) which make models less blocky.
Yes this is slowing down my work and making me consider alternative software.
I might misunderstand your post, but you can use the boolean subtract tool on filleted bodies. Can you elaborate please?
Again…https://www.youtube.com/@Shapr3d
This can work with basic shapes using the subtract tool but not as useable as using the sweep command to subtract from more complex/ multiple bodies at one time. It creates unwanted add ons in between the bodies which I am subtracting from.
There would be no difference between having a subtract option in sweep, and subtracting a swept body. The end results would be the same.
Image of the shape being subtracted
Hi Istvan, I can see where you are coming from but as shown in the below photo, I am unable to click done :white_check_mark: for the subtraction I want to achieve using the subtract command. If I was able to subtract the shape using the sweep command, this would work perfectly without the need to use another command and without the need to select all intersecting bodies. With a complex subtraction like this, I am unable to achieve it using the subtract command.
