Is there any possibility of intersection of curves (not bodies)?
I have not found it. So. I tried intersection of bodies but I don’t know if I there is any tool for deleting sides of body what I don’t need.
Any suggestion, please?
Hello,
I am not sure if you are looking for a tool for curves or bodies, please feel free to correct me if I misunderstood your question.
If two curves intersect in the same sketch Shapr3D notices it and the intersection becomes a snapping point.
If you would like to delete a part of a body, you can do it with the Subtract tool. Just create a body that covers the side you would like to delete and hit subtract.
Let me know if I could help you
Thanks for answer but I mean something else.
Let me give you an example. I made a curve in plane xy and then another curve in plane xz. So. I have two curves and each one is in own plane.
Is there any tool what can do intersection of these two curves?
Shapr can only intersect bodies not curves. I do not understand very well what you want to do but intersecting outlines will not work. Maybe you want to send a sketch of what is your goal?
Best
J
It’s a pitty. my goal is hull of ship where every line is 3D curve.
I can use intersection of curves (3D curve) as rails for loft.
Loft is great tool but it isn’t helpful without “rails” (for my hull shape).
If I could suggest any tip for improve work with bodies in Shapr3D. It would be rails for lofting.
This video summarizes it at around 2:40-4:00, I think - Autodesk and a few others support it - it’s a VERY handy feature for complex surface geometry.
