Centering an object on top of another
Hi, after you have drawn the large rectangle, the centre point is indicated and you can use this as a reference point when drawing the smaller perpendicular rectangle.
Draw a line accross the centre
Draw lines parrelel lines for smaller rectangle 1mm away from the centre line on both sides
Then delete the centre line and you will have a well centred pendicular rectangle with equal spaces at both sides
