Centering an object on top of another
Hi all… I’m working towards making a dovetail on an object and in this case I’m trying to center a smaller rectangle perpendiculaR to another larger rectangle. But I don’t know how to accomplish this… thoughts?
Hi, after you have drawn the large rectangle, the centre point is indicated and you can use this as a reference point when drawing the smaller perpendicular rectangle.
Draw a line accross the centre
Draw lines parrelel lines for smaller rectangle 1mm away from the centre line on both sides
Then delete the centre line and you will have a well centred pendicular rectangle with equal spaces at both sides
@ps23Rick
Alternatively make it easy on yourself by Sketching the two Rectangles as shown square onto the Grid set, in this case, to 0.5mm.
Make a Copy and Rotate to the Desired Angle and move it to the position required:
Literally cannot get anything to center on anything, all snap things on, great source of frustration
Hi @Cratgo, welcome to the community!
Try using align or translate.
Thank you, works fine on that kind of thing but won’t snap or align or transfer on anything else, had to create offset line as far as I could to get to snap properly or use calculator to manually figure measurements
Hi @Cratgo, the Align tool and the Translate tool are quite universal. Can you show an example where you got stuck?
