Making 2d drawings with centreline is very helpful. But I want the centreline for a particular bore dimension. Below is a image for reference ,where I need the centreline horizontal with reference of the bore .
Hi Rohan,
Just to make it clear, do you need only the horizontal line you drew here, or you would need both on the same bore?
Here I have drawn the horizontal line manually and I need both on the same bore.
Cool, thanks! Then it is the Centermark tool which will be the solution for you, but that’s in progress now and will be released soon.
Thank you for your support.
No worries
