Hole 2D drawing no center mark
Hi everybody,
I have a strange bug with 2d sketches recently. When I have a hole with a diameter lower than 8 mm I don’t have the center mark but a single dot on the outline of the hole.
The holes are on the side of a tube with a Ø40/34mm diameter. Does this strange behavior occure because the holes are not on a flat plane? I never noticed anything like that before.
Thanks for your ideas how to fix, or work around it.
(working on an Intel iMac with shapr Version 5.490.0)
Matthias
Hey @msx3000,
Could you please share your design (in .shapr format) to better understand the issue?
TIA
Hi H_Daniel,
I prepared a version with just the 2 tubes in it. The behavior is the same, I can’t get a center mark with the holes on the tube.
Tubes.shapr (105.8 KB)
Thanks for looking into it :smile:
Thank you for the design and for the report, it was very useful. The issue is created, we’ll investigate the root cause and prioritise it soon.
