iPad - 4.8 - Centerlines for 2D drawings
Hi everyone :rocket:
Take your 2D drawings up a notch with centerline geometries: 2-point and 2-line centerlines. All you have to do is select points and lines, and the app will mark up your technical drawings.
2_pt_centerline_eg_iPad
For more tips and tricks, drop by the Manual. And make sure to stay tuned for future releases, because we’re planning to unleash more geometry tools for 2D drawings, including 3-point circular centerline and center mark.
But that’s not all! Here’s a roundup of the other fixes in this release:
  • The Area Selection tool will no longer be triggered when you long-tap or long-click the Copy, Lock, or Scale badge.
  • Construction axes will be highlighted when you hover over them with the mouse or trackpad
  • Numbers and units in dimension labels won’t be cut off anymore.
  • Any selected body’s measurement details will accurately reflect any finalized changes.
Download and install version 4.8 to give these boosts a spin!
Thank you thank you thank you :+1:t2::+1:t2::+1:t2:
