Chamfer empty box
Hi, new to Shapr3D.
I am trying to create an empty box with a wall thickness of 1.5mm and Chamfered bottom edge. problem is how to duplicate the same chamfer on the inner surface of the box to maintain the 1.5mm wall and bottom thickness?
thanks
Here’s a way (assuming you already have the box shelled with the 1.5mm chamfer at the bottom).
You always can chamfer before doing shell. In that case shell will do inner chamfer for you.
That would be the preferred method. Mike’s solution demonstrates the offset face tool’s ability nicely.
Using history-based parametric modeling version you can always go back and do chamfer before shell. And that’s the real power of this type of modeling.
Wow, Thanks so much! this community is wonderful and a huge help!
