The chamfer/fillet function is not working properly.
If I try to make a figure through splines and fillet, the function does not work.
I don’t see any arrows to use that function.
However, even if it is the same shape, arrows can sometimes be seen depending on where click.
Are there any restrictions for using chamber/fillet?
There should be no difference in where you click. Can you please send us the Shapr3D with this issue in a support ticket? Please also share what version of Shapr3D are you using and upload a screen recording of the issue.
You can open a ticket using this link:
I just sent you a file and a screen recording video through that link.
Got it, thanks!
