Is there any way to enable collision between objects because I need to model how two parts will interact. I wish there was a way to “bake” a shape, lock pivot points, apply constant force, etc. When i use rotate, they just pass through each other.
Hi, we dont have simulations yet.
You can however use other softwares to simulate these forces. We export in .x_t, .stp, .igs. Export your shapr3d created bodies to a CAD that does simulations, it should work fine
Hi Daniel.
You said no simulation, yet. Does that mean, this is something possible to see on shapr3D in the future.
