Constraint overlap makes it hard to draw
I am using the app on the new iPad Pro m4 with pencil pro. While drawing hover highlight elements that we can select and I find my self struggling to draw simple line from a point when there are constraint on this same point. The overlap makes it very difficult to just draw a line as I will often end up selecting a constraint instead.
Is there a workaround ?
Thanks a lot !!
It’s a bug thatms fixed with the next release. You can hide the constraints until then under the sketch’s settings.
