I can’t select any node or intersection in drawing mode anymore because the constraints little square that pop up around the said node are positioned on top of said node, and when tapping with the stylus it activates the constraint.
Even when somehow i manage to get the node as a starting point, half the time i end up unintentionally dragging the node instead of starting a new line or circle.
