Constraints not displaying
On my desktop computer when I select Sketch the sketch menu appears and on the opposite side of the screen the Constraints menu appears. But on my laptop when I select Sketch the Constraints menu does not appear.
Any help?
Can you share a screenshot?
Thank you, doesn’t look great indeed. What size is this screen?
I changed the screen resolution several times but it didn’t help. I had a similar problem with AutoCad years ago. Certain screen resolutions caused buttons to disappear. The resolution right now is 1366x768. I’ve tried several different ones but it doesn’t seem to help.
I see, thank you. The minimum supported vertical screen resolution is 800. On very small screens like this, the constraints are under the More (…) menu on the left.
