Crease in Guided Loft
I am trying to create a horn shape using the loft:
The result:
I tried to rotate the circle of the small end with no luck. Shapr3d insist loft to flipped side.
I’d suggest adding another, slightly larger circle near where the crease occurred and then loft again.
It is a bug in the loft tool. Thanks for the report, we will fix it soon.
Thank you. Yes, adding circles in the middle, that’s how I work around this issue.
I can’t upload the file because I’m currently a new user. I hope this shapr file would help your investigation: Horn.shapr - Google Drive
