Create new sketch plane
Currently, adding a sketch most often add this to the last sketch plane, even when this is hidden! I usually have many objects in the same project and save them in separate folders, turning them on/off as required. I also tend to save copies of sketch planes and objects, especially when I’m applying non-reversible actions.
If sketch planes are hidden then don’t add a new sketch there but create a new sketch plane. Alternatively, add a “new sketch plane” to the menu.
It’s very annoying to have to shift existing sketch planes out the way or create at a different angle and then rotate back to the required angle.
It will (actually, already is) in the HBPM Beta. Give it a try :slight_smile:
