Hi everyone,
I recently started to use Shapr3D again and am exercising and would like to create a table that looks like the table in the pictures. I am struggling with the curves below the table.
If anyone has some hints and Tipps, I would be very grateful.
Thank you so much in advance for your help and regards to everyone in the world from Germany
Oh wow!!! This is so great and so helpful. Thank you so so much!
I was just wondering how you sketched it so clean in the first place.
I would do a rectangle, then a circle. And another inner rectangle. Then connect the outer curved line with a straight line to the rectangle.
Would you do it the same way?
Here’s how I sketched it. First the rectangle. Then the circle and made it tangent to the rectangle. I drew the 45° line at the corner of the rectangle to the center of the circle. Then I was able to draw a couple of 90° lines making use of the magenta perpendicular guide lines. This way I didn’t have to make the next 45° line tangent to the circle after initially drawn starting at the circle. Then I did the Mirror and deleted the two initial lines and did a trim. Let me know if any questions.
This is a much better way. Beautiful! Thank you!!
