Hello. I am try to create these curved elements but i am struggling. Can any one help.?
Greetings,
There are many ways to create 3D geometry in Shapr3D. Here is one way.
Create a cube shaped body and scale down one side. Create a hollow sphere. Intersect the two bodies and then use the INTERSECT tool to create the new desired body. Hope that helps.
-Mike
Greetings,
My method was meant to show one way to produce the spherically curved wall. I consider it Q&D (quick and dirty) for say, doing a quick design study.
But I must say the Robert’s method is more accurate if that is what you want to achieve. His side walls are perpendicular, or normal, to the center of the sphere while the top wall can be arc’d to a pre-determined height relative to the center of the sphere.
Nice going Robert.
-Mike
Thanks Mike
