Curved Fillets
Being able to add curved fillets is a feature that will allow a more flowing form to be modelled. This will knock off sharp edges and allow users to smooth the edges of a body.
I expect this feature to allow a curved fillet to be added to angular shapes, where users can alter the radius of the fillet as required.
Not having this feature is preventing me from having smooth edges on my designs, everything looks sharp edged and having to use a chamfer instead doesn’t do the designs justice.
Yes this is slowing me down, I am unable to create realistic forms.
@GregorL1009, Try this:
  • Select an edge and push or pull the double headed arrow that appears. This will fillet or chamfer as required.
You really should also take some of the tutorials that Shapr3D provides on their amazing YouTube channel. Basics like this are covered in great detail.
Many thanks, got it working now! Had a blonde moment :wink:
