Custom Sheet Title Block
I am a new user to Shapr3D and want to make a custom 2D drawing title block and wanted to know if that capability is available yet.
Is there a way to customize title block with your company logo
I want this too.
It would be great if you could add or remove input boxes that are able to be custom titled individually.
For example I often need to pass on more information than the current boxes allow, such as: material, finish, tolerances, delivery date, just to name a few.
Sometimes I have a note or two that needs to accompany a drawing, or I need a spot for an approval signature.
Things like this.
Using the existing text option in the drawings for all of this is frustrating and messy looking.
That’s the next item on the Drawing team’s roadmap. :slight_smile:
Any news on this? Your reply was Nov 2022, and now it’s Feb 25 and still no means to customise the title block!
While they are at it, here are a few more things they need to add.
2D Drawings:
  1. Let us draw lines
  2. Make labels automatic, pull the named part from 3D to automatically add to 2D drawing. When i put a note on a part, call it the part i named in the model.
  3. Fonts. Let us change the font size of dimensions and notes. If you use a big sheet size the text is way too small.
  4. Colors, Let us at least change the color of the dimensions and notes. A drawing with a bunch of lines the same color make it hard to differientate a dimension line from a part line.
  5. Let us move the arrow on the note. Sometimes i want to point it in a little diffferent spot than the default location.
  6. Let us dimension to a center of a line
