Feature Request - List of Problems and Solutions Drawings
I really like Shapr3D, and love it’s intuitive and agile interface. While I’m not an expert, as a designer, there are some features that would make my workflow smoother and reduce the need to switch between programs. It’s not a major issue, but improving certain aspects, especially in documentation, could save a lot of time. Here are some ideas that could further enhance the experience.
1. Inability to Customize Title Blocks
  • Problem: Title blocks cannot be edited, limiting the ability to modify their structure, fields, and format.
  • Solution: Allow full customization of title blocks, including adding/removing fields, resizing sections, and saving templates.
2. Improving Dimension Readability and Flexibility
Problem A: Dimension font size is fixed, making technical drawings hard to
Solution: Add an option to adjust font size for better clarity.
Problem B: Changing dimension direction (vertical, horizontal, absolute) requires accessing settings.
Solution: Allow dynamic switching based on mouse movement.
3. Inability to Add Colored Technical Drawings
  • Problem: Users cannot add views that display assigned colors and textures in technical drawings.
  • Solution: Enable an option to include color and texture details in specific
4. Inability to Set a Default Projection Angle
  • Problem: Users must manually set the projection angle (e.g., Third Angle Projection) for each drawing.
  • Solution: Allow setting a default projection angle to ensure consistency.
    to Set a Default Projection Angle**
** 5 Lack of Customizable Drawing Templates**
  • Problem: Users must manually adjust settings for each new drawing, such as line thickness, font size, projection angle, and title block details, leading to inefficiencies.
  • Solution: Allow users to create and save custom drawing templates that include:
    • Predefined line weights and styles.
    • Default font sizes for dimensions and annotations.
    • Standardized title blocks with editable fields.
    • Default projection angle settings.
    • Automatic sheet naming based on the folder or part name.
6. Inability to Download Multiple Drawings at Once
  • Problem: Users must download drawings individually, which is time-consuming when working with multiple files.
  • Solution: Implement a batch download feature that allows users to select multiple drawings and export them as a single file (ZIP, PDF set, or DWG package).
7. Lack of Table Support for Cut Lists and Data Organization
Problem A: No Interactive or Linked Tables
  • Issue: Users cannot insert dynamic tables linked to part dimensions, requiring manual updates when changes occur.
  • Solution: Implement support for interactive tables that update automatically with dimension changes, allowing for accurate cut lists and material tracking.
Problem B: No Option to Insert External Tables
  • Issue: Users cannot import tables from external programs like Excel, making it difficult to manage cut lists, BOMs, or material schedules.
  • Solution: Allow users to insert and format tables from external sources, ensuring proper data organization within the drawing.
Problem C: No Nesting Optimization for CNC and Laser Cutting
  • Issue: Arranging parts manually for CNC or laser cutting is inefficient and leads to material waste.
  • Solution: Add an automatic nesting tool that:
    • Recognizes identical parts in both dimensions and materials.
    • Optimizes material usage based on the cutting list.
    • Considers grain direction for wood and other textured materials.
    • Generates a visual layout for efficient material placement.
Also to add to your being able to change font for dimension size a big improvement would be to be able to change the orientation of the dimension to be between the dimension lines and being able to set the dimension as horizontal or vertical and make the arrows to be in or out of the dimension.
Thank you
Totally agree with all points. I’m looking forward to future drawing up dates
Yes, these are very useful feature requests.
it would be very nice if the ideas were implemented!
Great topic. I would add the possibility to draw arrows for notes and inserts symbols (like referring materials, hardware, finishes from the nomenclature)
hallo AngelP
hier hast du die möglichkeit alles zu kaufen, inklusive CNC. :smiley:
Mit freundlichen Grüssen
Andreas Desiderius Haudenschild
We absolutely need all of this, hopefully they get implemented fast
I agree with all of you Drawing improvements that are needed very much to make Shapr3D a good Cad program. Because exporting your models to a different program is not a solution and this need to be addressed otherwise they may lose many users.
Thank you
