I am confused with the default view, the grid and the X,Y,Z axis don’t seem to stay solid. I am used to have a ground-plane, and then we have the axis.
For some reason, it looks like this is always changing when I use it.
I am pretty sure its a user error, cause I just installed it and went through the first basic tutorials.
But not matter what I do, I can’t have a ground plane on the bottom, and then the axis around them.
I am in Front view, the ground plane should be on the bottom. Instead, it’s on the left and everything seems to be rotated.
How can I make sure that behaves like in any other 3d software, like 3dsmax, Blender, Maya, etc.
Thank you so much for any little help,
appreciate it!
