Deleting a sketch will also delete the 3D model structure
After generating a 3D model structure from a sketch, deleting the sketch will also delete the 3D model structure
Hi @Lisong ,
Yes, this is by design. If you want to use a direct modeling workflow, instead of deleting the sketch, just hide them.
@Istvan FYI, Fusion 360 has a separate “remove” function that keeps the sketch internally but removes it from view permanently.
