Trying to create a parametric project from non-parametric. Step 1 is to create sketches by projecting bodies. Step 2 should be to disconnect sketches from bodies; step 3 to recreate constraints etc. by hand. How do you disconnect the projected sketch from the object?
@drifkind one way to achieve that is to copy the whole projected sketch with the Move/Rotate tool.
