I have two objects with different heights.
Thank you!
Did you try selecting and aligning the faces of both parts instead of the edges?
Yes, I was trying to align the faces, but failed because the grey colour side face is not extrude from line sketch but spline.
It would be easier to suggest a solution if you could share your project.
Thanks for all the replies, I finally solve the problem with translate tool. Thanks again!
