I am uniting two bodies to each other and trying to perfectly match the edges so I can get a smooth chamfer, but I can’t quite get it perfect and it causes the chamfer to get whacky. Is there a way to snap the body edges together to make it a continuous edge once union’ed?
You are talking about the lip on the left thats union together? The union looks ok can you show in more detail where the union is quite not right?
When you chamfer are you doing it one side at time or all sides at once.
Thanks for replying!
Attached is a closer look of the intersection prior to union. I don’t see any obvious offset. Though the edge of the “handle” and edge of the “main body” are recognized as separate items, so I guess there’s a minuscule offset. I just want to find a way to make sure they’re precisely aligned on both sides.
The only solution I found was to start over in the sketch phase and snap points there. But if I want to copy the “handles” from another shape and adjust the dimensions to fit.
Thanks for replying! For existing bodies, the align tool pops the body to the center of the plane. Since one is a different height/thickness than the other, it goes to the wrong place.
I have figured that the only way to get around this issue is to resketch the item from scratch to snap to the sketch of the existing body. I wish the align tool can be improved to allow edge to edge snapping.
Ya sometimes it’s faster to just re-sketch vs align. Shapr comes with very limited alignment and options, it prefers getting it more right during sketch.
The Align tool will align an edge to another edge but not the face, so you align the face, now you have to align the endpoint.
