DO NOT INSTALL macOS 15 (Sequoia) beta 1!
Will add some more context to error, this time from lldb:
2024-06-25 21:54:56.641123+0300 Shapr3D[1934:22488] [CursorUI] ViewBridge to RemoteViewService Terminated: Error Domain=com.apple.ViewBridge Code=18 "(null)" UserInfo={com.apple.ViewBridge.error.hint=this process disconnected remote view controller -- benign unless unexpected, com.apple.ViewBridge.error.description=NSViewBridgeErrorCanceled}
2024-06-25 21:54:57.693778+0300 Shapr3D[1934:22488] Warning: The selected font is a system font, but the macOS font panel will not show system fonts to the user. When configuring a text view to display rich text, you should only use fonts that are available for selection (see NSFontManager.availableFonts). A fallback font (Helvetica) will be shown to the user instead.
2024-06-25 21:54:57.711206+0300 Shapr3D[1934:22488] Warning: The selected font is a system font, but the macOS font panel will not show system fonts to the user. When configuring a text view to display rich text, you should only use fonts that are available for selection (see NSFontManager.availableFonts). A fallback font (Helvetica) will be shown to the user instead.
2024-06-25 21:54:57.773103+0300 Shapr3D[1934:22488] [Window] No window found for context 335e8925
2024-06-25 21:54:57.776243+0300 Shapr3D[1934:22488] [Window] No window found for context 335e8925
2024-06-25 21:54:58.634370+0300 Shapr3D[1934:22488] [general] osEligibility.status reasons is empty
Quite likely that we all will need to wait for devs to start using newer xcode. Meh, will need to learn to work with iPad and pencil fast :slight_smile:
