Does Shapr3d work better on higher GB ipads?
Do the GBs effect how well Sharp3d works?
Quicker or smoother? Would it work better on a 128gb or on a 256gb ipad then on a 32gb one? & Is one best?
Hi cclb,
the amount of storage in the iPad makes absolutely no difference in the performance of Shapr.
(On the other hand, I think you should buy one with a bigger capacity if you can afford it. Apps for the iPad can be pretty huge and you can run out of space fairly quickly if you have only 32 GB.)
Thanks Tamas, great to know.
