First time in Forum. Thanks in advance. I need to drag a DWG import to a specific point. The design is filled with little lines. Is there a better way to blue mark a whole part of the design than marking each and every line? Thanks
Use the Items/Groups/Folders Icon at the at the bottom Left:
Highlight/Select Sketches 01 [be aware that the # may vary with multiple Planes in use]. The whole of the content will be highlighted.
Ooops! Just noticed DWG, not something I use. It may be in a differently names Folder.
DWGs imported as sketches, so this will work.
