Ash1
July 25, 2019, 11:16pm
1
Hi when I import dwg file, all sketches show as empty
Istvan
July 26, 2019, 9:42am
2
Hi! Can you send the problematic DWG file to support@shapr3d.com ?
Erstf
June 10, 2021, 9:26pm
3
Was the issue resolved? I have a similar symptom - import goes through, but the imported file shows up empty. I’ve tried viewing the drawing in an adobe program, and there i can see it…
KPeter
June 11, 2021, 9:51am
4
Hi @Erstf , there are some limitations in the supported drawing elements. Please take a look at this post below, I hope it helps:
Thank you for your patience dear people of the forum, let me share some basic info about the dxf/dwg file transfer with Shapr3D.
If you wish to import a drawing, please pay attention to the supported data types which are lines, polylines, arcs, Bezier curves, circles, and ellipses. Annotations, text elements, and 3d objects are not supported. If text elements are exported as curves, Shapr3D is fine with them but you may end up in letters that are defined by ridiculously lot control points - it …
I am having a similar problem importing windows in dwg-format. The process of importing never ends?
