I had some issues with my dxf /dwg files when I send them to the lasercutter and watercutter. In shapr the files seem perfectly closed , but when opening them in other software they are not. I therefor have to Fix all the drawings in another app before I can continue
Hi - sorry to hear this - can you please send one you had issues with to support@shapr3d.com and we will fix the problem asap
Thank you . I will do that.
What’s the solution here? I too have a similar issue. My sketches look normal in Shapr, but when exported they do no translate properly, or show up at all.
I fix the files in another program called deepnest. It is quite a hassle , but its to only way to make the files readable for external producers.
Circling back, I now know why this was an issue. It was operator error, i was not projecting the sketches in the correct plane. Back in 2020, I was very new to this, now a little better.
