Educational function blocked
I have a colleague who has an educational account and when he wants to make a cut on a technical drawing it tells him that he has to go up the range on an educational level when it is already the case is it normal?
That’s definitely not normal, there are no limitations on Drawings for educational licenses. This sounds like a bug with the Section View tool. Could you please attach the project so we can investigate it?
rangement foret.shapr (351,0 Ko)Yes of course, here is the document
After other tests on another file it does not encounter the problem
