I’m trying to model an ellipse with a scalloped edge (similar to this). The repeat tool will repeat around a uniform circle but not an ellipse. Is there a way of doing this in Shap3r?
Yes, the Pattern tool only works in linear and circular (for now).
If you don’t mind a little distortion, you can pattern scallops around a circle and use the non-uniform Scale tool.
