I have imported a step file (actually 5 different files 5 different times in 5 different new drawings from grabcad, all made Shapr3D crash)
So then I took the time to model the sheet of expanded metal I needed in a new drawing
I tried to model one 5’x10’ sheet of expanded metal…….a single sheet and it made Shapr3D crash, when I tried to “translate - copy” the last 24” of a single sheet.
Thanks, as I can see it is a pretty detailed patterned shape. It can easily happen that the iPad simply runs out of memory (RAM) while trying to open the file. Is there any reason why you need the full detailed wired shape in full size for modeling?
Could you please tell me if Shapr3D actually crashes or does it take a significant amount of time to open the file?
Hello @Madman,
The bottleneck here should be the RAM, not the storage. iPads regularly have a few gigabytes of ram accessible, however, the storage can be terabytes.
Arraying hundreds of bodies, even simpler ones like a sphere may need an unbelievable amount of performance relative to the geometry, but that should be rendered, etc. Please use a simpler model to represent this part, like a transparent planar body, while you could show the detailed metal part in a smaller model where just a few pieces are patterned.
Hi there Madman,
Expanded metal or even punched sheet is pretty much a PITA even in high end cad on a workstation, it’s the number of complex surfaces, and if you want to shape it-!!!, good luck with that. Generally speaking for representing it I usually end up using a texture but if you want engineering calculations then you either have to create your own material or do it long hand.
Kim
