Hello,
Today I was exporting my House from Shapr3D as a ZIP File with all my Objects (Windows ,Doors, Roof… ) as OBJs. When I Unzipped the folder on my PC and dragged all the files into Blender I noticed some parts of my house were missing. I found out that the Parts that were missing had a " * " in the name that Shapr gave them. The " * " came because I had duplicated them. This is a bug and needs to be fixed please. It is a lot of work to find all the Objects with " * " and having to rename them so they can be exported.
Example Files:
Hey 21Suspect,
Are you sure that the items with " * " aren’t exported?
" * " in the filename is not supported by Windows so Shapr3D changes these to " _ " in filenames. In this case you should find files like: Körper 35 (3)_55.obj. Based on my investigation, import of these files work in Blender.
If that’s not the case, can you please share a workspace with which you have problems during export? We would appreciate if you could let us know your Shapr3D app version, export settings and Windows version as well.
Hi Daniel I finally know the error. I found a log file in the ZIP that I exported that revealed the problem. The Problem is not the " * " but the german Character " ö " (o with 2 dots) witch stand for Body in English.
As I cannot upload a text file here, this is the log file:
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 0611.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 104 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 104.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 105 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 105.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 106 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 106.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 107.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 108 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 108.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (1) 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (1) 3.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (2) 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (2) 3.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (2).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111 (3).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 111.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 118.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 119 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 119.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 120 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 120.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 121 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 121.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 125 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 126.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 14 (1) 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 14 (1).stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 14.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 15 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 15.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 16 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 16.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 17.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 18.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 19.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 20.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 21.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 22.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 23.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 24.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 25.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 26.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 27.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 28.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 29.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 30.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 31.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 32.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 33 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 33.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 34.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 35.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 3512.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 3513.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 37.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 38.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 39.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 65.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 6511.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 68.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 70.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 701.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 702.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 72.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 73 2.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 73.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ko?rper 74.stl
failed
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Lineare Muster 03.stl
done
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ordner 03.stl
done
importing C:/Users/fabiv/Downloads/valeria stl/valeria stl_Ordner 05.stl
done
Hey @21Suspect,
Please open a support ticket and send us the files with the version number of Blender you’re using.
I just changed my Language to English and now it works. By the way in german the “ä” “ö” and “ü” is known to cause problems thats why in germany it is normal to write “Koerper” instead of “Körper” as this avoids errors with charachters. Maybe they could change that
