Hi all!
Thanks in advance for any help.
I started only yesterday with Shapr3d (I used other 3d modelling tools until now), but I can’t quite understand why, when I’m trying to export in .stl, I have this error message: “Export failed. Failed to create file”.
The model itself is not complex (it’s not even perfect, it’s just a quick prototype that I need to print). I can’t see gaps, I erased all the fillets to be sure that was not the reason for the error, but I’m just stuck, and I would really like to avoid re-doing the model.
Here’s the link to the workspace (is it ok if I put it here?):
And here are some screenshots:
