indrek
1
I’m trying to export an .STL file, but keep getting “Export failed - Failed to create file.” error message.
It’s a pre-drawn object imported from a .STEP file.
Using the latest iOS 13.3.1 on iPad Pro.
Any ideas, what might be an issue here?
Thanks,
Indrek
Hi, this a file geometry related issue. It could be edges not properly aligned or that there is a hole in the model.
Please send the Shapr file to support@shapr3d.com. We will look into it and then get back to you as soon as possible.
indrek
3
Ok, will do. Thanks for the quick response.
