Extrude to cutout shape
While extruding a shape to change the outline of an object or body, sometimes the wrong body does the cutting. It’s like I’m using a soft stick of butter to shave an object, but instead the target object ends up cutting a negative into the “butter”
I have subtract enabled.
How do I prevent the nail from putting a hole into the hammer?
Screenshot of the problem might help us help you.
As you are dragging the face you should see a little blue thingy you can click on and change attributes of the operation: New body; Subtract etc..
