Eyewear Design Update
Hello Community,
I reached my goal to create eyewear based on all necessary parameters. I create a acetate frame with heat inserted hinges and inserted clear lens. Lens Base Curve 4. Frame Base Curve or Frame Wrap 2. Forward leaning 10°. And all other angle set correct. This prototype is printable. I will design now some frames with hidden hinges for print frames to order prototypes. Next step would be generate design that can be adapt in a lot of cases.
I also tried to render a clear frame out of it.
Hello Dennis_L,
Nice work, impressive. Thanks for sharing.
Thank you. More is in the making :+1:t2:
