Is this something that you actually intend to manufacture or is it more just for fun?
Why did you make the dip bar so low? The multi-bend bars add manufacturing difficulty, not only in the bend processes themselves, but also because it increases the tolerance stack-up which could result in alignment issues when assembling these bars to the main structure.
Functionally, the lower position risks a taller person’s knees actually bottoming out with the floor. Even if there is enough clearance for that, the lower height may prevent dips using additional weight (often hung from a chain to a weight belt). By simply extending dip handles from the arm rest beam, the design would be more functional as well as more manufacturable.
Also, if you’re going to use gymnastic rings, you might want to consider attaching them to the frame using straps. The instability from the straps helps work additional muscles. If you widened the distance between the foot pads, you could lengthen the straps to enable ring push-ups.
