First project
Hi everyone!
I wanted to show off my first model, which is a knife. I’m just starting my adventure with CAD, so I’m mega excited that I managed to finish it. The workmanship isn’t perfect, but I’m happy with the result for a first time. I would welcome any suggestions and feedback! :slight_smile:
If I can figure out how, I’ll make it in future
I attach the picture
and look forward to your comments!
It’s not bad for a first time, bravo!
I find the handle a little too thin, not thick enough.
The pattern on the handle is a bit rough.
You will also have to work on the spikes (fillets, bevels…)
Thank you, Jean, for the advice!
I made the handle thicker and also worked on the pattern as you suggested.
I was having trouble with the fillets, but after redoing the sketch, everything is working well now.
I think this is much better. Well done !
Pourriez-vous donner une adresse de publication nous pourrions ainsi voir votre couteau sous des angles et zoom différents. Merci
Sure, no problem.
yes, it’s cool :slight_smile:
L‌es épaisseurs sont très bien proportionnées. Encore toutes mes félicitations. Charly44300
