Found a crash (Redo Import)
Reproducibility: 100%
I found a crash.
  • Steps to reproduce
    • Open a new drawing
    • import gears.dxf
    • move the gear drawing to anywhere (I just slightly drag it)
    • On keyboard do Undo (CTL-Z) to put the object back to the starting point
    • On keyboard do Undo a second time (CTL-Z) removes the imported file
    • On keyboard to Redo (SHIFT-CTL-Z) and the app will crash with the attached stack trace.
This is the gear demo from the DXF / DWG wrong paths thread.
Gear1.dxf.zip (21.2 KB)
Crash Log
Hopefully, you can symbolicate this:
Process: Shapr3D [99823]_crashlog.txt.zip (43.3 KB)
This no longer crashes in Version 3.57.0 (726)
