Furniture and interior design
I’ve drawn the door surround successfully and am working on a set of shelves that will continue on top of the door. The first shelf is off because I didn’t take into account the 18mm support. I can’t nudge the shelf into place. I’ve drawn a line where the next shelf should be but it’s very complicated to draw it because the other shelf is in the way when I try. I imagine this will be very easy once I’ve figured out how to do it. I used to use Vector works extensively where I could extrude and group and nudge and snap things into place. This is a drawing for builders to build the shelves so it must be relatively accurate. Any pointers would be welcome, thank you for your very quick response!
Caroline Wilson
