Furniture - Working with large and small objects in the same design
0E3BE29A-20EA-40B4-A089-46F58D818BCD
Seems to me that this is easily done using the Offset tool and possibly Construction planes. Don’t understand why this seems to be a scale problem.
I am working on a building and regularly do detail work (say a light switch) with no problem. For small detailed items, it is often better to create separately and then Move them to their correct position.
7C72EA3F-CC07-4FD7-8575-D6E93DDC2669
Hope this helps…
Tommy,
Must have missed the offset line option along the way
Yes that should make a big difference for me
Still doesn’t explain the dimension being miles away from where you are working though
Thank you
Kevin
Kevin,
I have noticed the far away dimension once or twice. It’s because the view point is far away, I think. It is similar to when you enlarge an angled set of lines. You will eventually approach an angle that can’t fit the view point and it seems to blow up.
I saw this when learning how to approach designs. Have never had further problems. Good luck…
