Hi! I got this vector file that I exported as .dwg to be able to extrude it, etc. on Shapr3D. Unfortunately when I import the file into de app I’m unable to extrude it. It’s just lines and curves and won’t give me the option. I’m not sure what I’m doing wrong. Maybe I’m missing something? I imported the outline of the original shape, no filler color, and that didn’t work. I also tried importing the outline with a filler color and that didn’t work either. Also tried .dwf file. with no luck. Notice on the pictures I took how the shape is and that it will only select the points but won’t let me select in the middle in order to extrude it. Help!
Whenever there is no sketch filling, it means the sketch isn’t closed. There is a hole somewhere in the sketch.
Easiest way to find it is to start cutting the sketch using straight lines, this way you can find the problematic part relatively quickly.
