Height change mechanism
Dear community,
I want to sketch a stick that you can change the height with. By using this Metall button.
I was wondering if one of you ever sketched the following mechanism:
I have not yet de-put it so I don’t know the exact meachanism inside. But I was just wondering if there’s is something like that already existing in this community.
Many many many thanks in advance and greetings from Germany
Hi, it’s quite simple, something like in the picture below. In the tube, there should be a leaf or coil spring to lock the button
Look up Snap Buttons from an industrial supplier.
https://www.mcmaster.com/snap-buttons/button-pins-for-telescoping-tubing/
You guys are the best! Thank you Peter again!! And I lookedeverywhere for those button pins and then I finally saw you even added a link. Great !!
