Help with copy of real model
Hello I would like ask how draw this three imaginary round objects to each other please ? Ring + concave bottom and middle sphere.
And the also back side which hollow shape. Please do you have some idea or tutorial similar.
Many thank you. Ondrej -
This would be ideal for drawing a cross section of the shape, then revolve it around the center axis.
Here is a quick video of a similar shape, to show concept of the methodology. iCloud
Perfect idea. Thank you. But how you draw this irregular curves please?
I drew those using the Spline tool, then used Offset to create the parallel line. I then connected the ends, to close the shape.
Hello. This is my result. Thank you for help. Ondrej
Great job!
