Hello, I’m trying to add a consistent concave path between these two outlines. The purpose is to give the guitar some shape, similar to how PRS guitars are done but on a Telecaster design.
Interesting just looked at PRS Guitars on youtube .
Im about to build a guitar for my son.
I use Vectric aspire alot for my cnc and in Aspire we have a thing called”sweep between 2lines”
You there draw 2 lines then apply the curve as a model and it sweeps between the lines.
Must be possible here also with sweep function as it works similar
Simple test that will work as i thought
I think @Jonas method is the best way to create the curved surface you are after.
Here is a very different and interesting approach. You can project Imprinted Body Edges on a surface and lift it with the Move-Rotate tool. This method may not apply here but I just wanted to share.
