Hide dimensions for objects not being worked while sketching
*The problem that this feature will solve:
It becomes very difficult to work on small objects with a lot of sketch element. See the screenshot below. How in the world is this not already a feature.
The screenshot should show this plainly. In order to work on elements of the sketch, I have to constantly zoom in and zoom out just to be able to see what I’m actually working on.
Hi @mwagener, does it make it easier for you if you set “Constraint & Locked Dimension Visibility” in the Constraint Settings menu on the right to “Selection-based”?
