Turn off Constraints view
It is nice to see the constraints, but is there a way to toggle their view on and off ?
My sketch is cluttered.
You can change their visibility in the Constraint Settings.
No, I can’t. All I can do is toggle between section based and show all. Either way, all the line lengths still are displayed.
Joe O.
(Grandpa Joe)
Please also visit
http://grandpajoespuzzles.com/
Are you running version 5.300, or an older app version?
Hey Joe,
what you see here are dimensions and not constrains, thats why they do not hide - by standard they are visible as long as you are in the active sketch.
If your design-intent is that all the rectangles shall remain the same size for ever you may sketch them and give the sketch-lines an equal constrain - then you could drive the size just by dimensions on one rectangle.
I personally try to avoid complex sketches in S3D, because they are pretty useless after one used them for creating a body, due to the lack of associativity between sketches and features/bodies.
I would create a single body and make a pattern from it.
HTH
Cheers Matt
That’s a good idea Matt :+1:
I am using version 5.281
Update to 5.300 :wink:
